Need Diagrams for Brake/Tail/Dash Lights- Wires, Wire Color, etc.
Buy yourself the most important single tool you could have, a FSM. they are priceless when it comes to diagrams.
Where can I get them?
I need this problem fixed. I do not understand why the lights aren't working. I did not know the brake lights were tied into the tail/dash lights. Usually if you blow a fuse, only the dash and tail lights don't work. But my brake lights aren't working either.
Ok so I got a test light. Found a bad brake light (stop lamp) fuse. It looked fine, but it wasn't. Replaced it and now the brake lights work.
But the tail light is not getting any juice at the fuse box. Fuse checked out good in another spot. But I am not getting juice to it at all. So this would mean I have a problem between the fuse box and ECU?
