can t shift anymore !!!!
Marceldsm
321
3
Jan 13, 2010
Montreal, QC, Canada
so here is the story i have a fidenza flywheel, ebay stage3 puck disk, xtd stage 4 plessure plate
new fork new fulcrum( shimed) stock master and slave from factory since 91
its almost inpossible to shift in first very had
second is hard but not like first
number 3 gear if the car is not moving and i go in gear it will grind
if the car is moving it will grind only on certain ocations!!!
4 and 5 are hard but les the 2 and 3
whas is cousing all this
the master is full OF LIQUID
what do i check first
slave
master
MASTER AJUSTMENT
OR
SOMETING INTERNAL LIKE A SPING IN THE CLUTCH
tHANKS IN ADVANCE
CAR HAS DROVE FINE LAST 700 KM KNOW I CANT SHIFT ANYMORE
possibly the trasmission. i know in my 97' talon i had bad syncros. Was hard to shift into first. Hopefully this isn't the case. But just thought I would mention it.
EDIT:
maybe yours doesn't have a synchronized transmission though... i just saw yours was a 91..sorry for jumping the gun there also what kind of transmission fluid are you using? :/
Does the car have DSMlink?
If so put the car on the two step to see if it rolls. If so your clutch is hanging. I personally have to check my car at 7000 because at 6500 it did not show.
Can you move the slave rod by hand?
i will let you dudes know
update
yes i can move it all the way by hand
so what dose it meen
is there a slave master problem
dose it needs ajustment or someting else
thanks again in advance
anybody !!!! do i change the master and slave or not
Your clutch is not disengaging causing it to drag, I had an identical issue when my disk popped 2 springs. Its worth checking the adjustment and slave for leaking just incase but sounds like you may have to pull the tranny. You could pull the rubber boot off the fork and have a peek in there, it may not reveal everything but you could see if your pressure plate bolts have vibrated loose.. I had a bolt fall out when I pulled my rubber boot out...my first bad sign LOL
By the way, don't drive it until it goes into gear normal and passes the drag test because it will result in lots of wear and possibly damage.
the master is leaking so there you gooo :rocks:
hope what will fix the problems lool
Sounds silly but how's the fluid look? I'm having the same issue and noticed my fluid was black cleaned it out until it was clear and it shifted great. But for some reason it gets dirty again within a couple of hours and starts shifting like Crap again.
