Leaking AEM fuelrail....Quiksteel?
sleepypsi
32
Mar 3, 2008
Star, North Carolina
I heard the the AEM fuel rails are known to leak even after you replace the orings. I've read that some people have used quick steel around the oring area and didn't have any leaks after that. Besides it looking like shit would there be a problem doing this?
IF you want something that can fail down the road and catch your car on fire go ahead. I would either tap it and screw in some -8 fittings , weld the -8 fittings on or just get a stock fuel rail.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
