Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Welcome to DSMtuners
Newbie Forum: Beginner/newbie/general DSM modification questions. First mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. Probationary Members must limit their tech posts to this forum and sub-forums.
Reply
LinkBack   Thread Tools
Old 02-25-2011, 09:44 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
MOTORHEADMIKE's Avatar
Tech Posts: 1
Reputation: MOTORHEADMIKE is an unknown
Angry
Galant VR4 starts - won't stay running!
91 galant I picked up that a buddy had sitting for four years. Swapped motors.. Now has 7 bolt engine, stock EVERYTHING (car is for wife). There was some nasty sludge in the gas tank after four years and we cleaned it. Replaced injectors & fuel filter.
The car turns over perfectly then dies almost immediately. Will idle 3 seconds at most, you can rev it up, but it will NOT stay running. It smells like a lawnmower. Just tried changing TPS, no difference. Injectors have power and are keeping power.. Help?
mark post as helpful recommend reputation points    Reply With Quote
Old 02-25-2011, 09:52 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
805DSM's Avatar
Car: 3000GT VR4
Tech Posts: 205
Photos: 44
Classified Ads: 1
Classifieds Rating: 1
Reputation: 805DSM is an unknown
Make sure that all couplers are conected and that u dont got any boostleaks. Specially in the throttle body . Also make sure the Mass Air Flow sensor is connected or even working. And also check the fuel pressure , the fuel pump might be going out.
____________________________
- ALEX
View photos of this member's car
Old 02-27-2011, 01:15 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Russman1986's Avatar
Tech Posts: 67
Photos: 7
Classified Ads: 1
Classifieds Rating: 5
Reputation: Russman1986 is more helpful than not
Check the fuel pressure for sure.
Old 02-27-2011, 01:43 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
daddybonez07's Avatar
Tech Posts: 248
Photos: 16
Classifieds Rating: 36
Reputation: daddybonez07 is an unknown
4 years is a long time. But you should check the maf sensor as stated, also get yourself a volt meter and check the coolant temp. sensor. The wires on these cars turn brittle from being so old when you did the motor swap you may have weakened a couple of the connectors. Just do a once over before replacing anything and start performing checks with the volt/ohm meter.
Old 02-28-2011, 03:45 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
toybreaker's Avatar
Tech Posts: 335
Classifieds Rating: 0
Reputation: toybreaker is an experienced, knowledgeable member worth listening totoybreaker is an experienced, knowledgeable member worth listening totoybreaker is an experienced, knowledgeable member worth listening totoybreaker is an experienced, knowledgeable member worth listening to
Make sure that the ecu capacitors have been changed.
They have a nasty tendency to leak while a car is down for an extended period.
The electrolyte that leaks from the capacitor casing contains boric acid and amonia salts and will damage the ecu board, leading to all kinds of problems, including the one you are describing.
After you have investigated the ecu, it's time to start checking the basics relating to the fuel pump system.
The fuel pump runs anytime the key is in the start position.
After the engine starts, the ecu controls the fuel pump operation by grounding one leg of the fuel pump relay coil, located inside the mpi relay.
If the ecu doesn't "see" the engine running, the ecu won't ground that leg and you wont have power at the pump when you release the key to the run position from the start position.
To check for this, remove the fuel pump cover plate (in the trunk under the carpet, drivers side) and check for power on the black/white wire.
If there is power there while cranking, but it goes away a few seconds after the engine starts, you will be checking the mpi relay/crank angle sender and a few other things related to the fuel pump control circuit.
Good luck, and check out that ecu PRONTO!!!
It's a common problem that left unrepaired will cost serious money to remedy.
Reply
Bookmarks
Tags
galant, idle
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 612
234 members and 378 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
