Josh_92DSM
- 45
- Jul 11, 2010
Sparks,
Nevada
Ok so i have a 92 talon tsi i traded it for my old honda pretty much a steal
anyway the guy said he snapped a timing belt but had the head rebuilt cause it caused the valves to bend just fyi
anyway when the car is idling it sits there at like 1000rpm then goes up to 1500rpm then it keeps doing that up and down whenever the car is idling the guy said the idle contorl valve needs to be adjusted is this true or could it be a sensor or a boost leak or what could it be?
also i was reading on here and there was a thread on what happens if your timing is off by a tooth or two and it said if it is off by two teeth then you will hear a knocking like sound coming from the engine i hear this on my car is it possible that they could of timed it wrong and thats why i hear these sounds? and i have an aftermarket boost gauge and whenever i step on it everything is good boost up then when i let go of the gas the boost gauge itself makes a chsshhhhhhh sound and wont stop till go into boost again?? and the guy before me took off the recirculating hose for the bov and i just put it back on and the car seems to be working better sucks to not really hear the sound of the bov but healthier for the engine anyway i just wanted to give you all the info on the car and hopefully someone can help me out thanks
