P1500 and P0125 need help guru
rarest_90_DsM
285
3
Jul 21, 2004
akron, Ohio
I have searched and no one has really solved the P1500 issue any help will be appreciated! As for the P0125 coolant temp sensor?
finally got rid of the p1500 code new alternator. Still have the p0125 code along with a funky idle it starts idling normal then just before the cel comes on it idles up to 1000rpm then bout a mile down the road 1500rpm then cel and stays at 1500rpm any suggestions????? what would cause it to idle like this?
just put a new o2 on its one of the universal ones sorry should have mentioned that and im pretty sure i wired right but if you know off hand you could post it.
Put in a new thermostate yesterday and got a CEL on my way to work this morning this thing is making me angry what should be next to get replaced the coolant temp sensor is about the only thing left any help anyone have this problem before?
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
