DOHCAccord
- Jan 9, 2006
cincinnati,
Ohio
Ok, heres a weird issue and im inclined to believe the guys at the shop. I was on the dyno this last saturday and at 5k rpm in 4th the engine just hits what seems like a rev limiter. I adjusted everything in my laptop making sure nothing was causing it. A total of 5 pulls later and each time it hit like a brick with the engine popping. The afr showed it going form 12-1 up to 13--1 then spiking to 14-1 at the engine popping. i iknow its going lean and part of those runs was to see how it was stacking up. now, i drove the car for months without issue, and that day i made mulitple highway pulls setting my boost controller with out a single issue. I pulled the car off the dyno, hit the highway and a full pull. no issues at all. the guys think it running out of fuel, but i dont know yet.im awaiting my fuel pressure gauge and then ill know if its dropping pressure, but its sappose to have a 255 walbro high pressure, again sappose to by a shop i though i could trust. what do you guys think.
. Use an EMS system. try to add more pressure when throttle is at WOT. Then do a pull. Just experiment!!
