1st log on E316g+ E85.....im a believer 60-80 (1.91)
boosted86
414
5
Sep 7, 2005
Weston, Florida
ok well heres my first log on my e85 setup. very impressed. this is at 25psi falling to about 23. brought the timing up and leaned it out a bit,.. 60-80. (1.91) let me know if you guys see anything that will yeild some more power. i was thinking about bringing the boost up to 27psi but im not sure about the limits of this little 16g. also my AFR's about about mid 11's should i go leaner? thanks,
I would stay around 11.1-11.5 afr. I run a spike of 30psi no problem. I would turn boost up just a little. I dont have dsmlink on this pc so I cant see your log. What timing are you seeing?
right now im about 18* by 5.5k. ive poted this same thread on dsmlink forums and numerous people have toldme to bump my timing up to 20* by 4k, but im little scared with peak cylinder pressure...
