engine missfiring
Make sure the injectors are sealed properly. I had air getting into mine and no fuel coming out. Take some carb cleaner and spray near injectors. If engine revs up you know your seals are seal properly. Also I assume you took the spark plug wires off to get to the injectors. Make sure you got them in the right order (4123) and make they are tight.
Can you give us a little more information? Is it missfiring at idle, or when you pull? If it's when you pull, what rpm range?
How are you regulating fuel with the larger injectors?
You can missfire from being lean or rich.
Well there's two causes to misfires: Ignition problems, or fuel delivery problems. Start the car and start pulling off spark plugs wires. If the idle doesn't change, you've found the bad cylinder. OR, if the idle doesn't change at all once you've pulled them all, then that means fuel is the cause of your misfire(most likely). Check the plugs, though. Easiest thing to do first.
+1 probably the easiest and fastest way to rule out one or the other.
Also, a fuel problem would be affecting all cylinders(unless you just have a bad injector) But like everyone's said, plugs and wires yo.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
