Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 10-03-2008, 05:52 PM   #1 (permalink)
Proven Member
LTUDSM's Avatar
Region: Tri State
Classifieds Rating: (0)
Reputation: LTUDSM is more helpful than not
daaaamn im so stupid!!!!!
Today i fired up my car.I swapped the shortblock. I id the BSEK and i forgot to rotate the rear bs bearing to block the hole.The front one i rotated and blocked the hole.So when i fired up the car,the oil pressure on a cold start was good 55psi.After the car warmed up,im getting 5-7psi of oil pressure.While im driving,the oil pressure is good,i did one WOT pull,and my oil pressure jumped to 100 psi. So my question is.should i really need to take everything apart again, and rotate that one stupid bearing to block of the hole,or should i just keep driving like that????
Offline
Related Auctions
Sponsored Links
Old 10-03-2008, 07:30 PM   #2 (permalink)
New Member/Lurker
talon_swift7834's Avatar
Region: Midwest
Reputation: talon_swift7834 is an unknown
My engine does the same thing. I'm pretty sure it's normal for some dsm's to run that high of oil pressures. It did it with the factory engine as well.
Offline
[posts] Reply With Quote
Old 10-03-2008, 07:31 PM   #3 (permalink)
Proven Member
Region: Midwest
Reputation: giovanniv is an unknown
If i was you even though it would be a big pain in the ass to do is take the motor apart and do it the right way
Offline
Old 10-03-2008, 07:34 PM   #4 (permalink)
New Member/Lurker
Region: Midwest
Oh! I forgot to mention that when you remove the balance shafts; I believe just by doing that you raise the pressure a little bit. I also run the forward facing oil filter bracket, so i have no oil cooler and that raises it as well.
Offline
Old 10-03-2008, 07:45 PM   #5 (permalink)
Proven Member
LTUDSM's Avatar
Region: Tri State
so if ill take out my oil cooler,should i be good or do i still got to take the engine apart???
Offline
Old 10-04-2008, 10:21 AM   #6 (permalink)
New Member/Lurker
Region: Tri State
Reputation: talon410 is an unknown
im not sure if you gonna get higher oil pressure bypassing the oil cooler,somebody who knows more bout that,should help you out.....
Offline
Old 10-04-2008, 10:25 AM   #7 (permalink)
Proven Member
Region: Tri State
Classifieds Rating: (3)
Reputation: 90laserRSfwd is an unknown
You only have to block off the front BS bearing oiling hole. The way to relieve some of the oil pressure is to port the oil relief valve in the oil filter housing.
____________________________
e85 = Motivational Relocation
~ Jayson ~
Offline
Old 10-04-2008, 10:32 AM   #8 (permalink)
Proven Member
LTUDSM's Avatar
Region: Tri State
well i blocked it off.but still im on low side ,im getting like 5 psi of oil pressure.... im thinking to go and try to bypass the oil coller and see if it could help me to rais up the oil pressure. BTW If im really on low idle lets say 700-750,could it affect my oil pressure??? because when i hold up to 1k rpms the oil pressure goes to 20-25 psi.I got a cel and it seems ,that its affecting my idle,I think is TPS sensor,because when i unplug the harness from the TPS,the idle doesn't change
Offline
Old 10-04-2008, 11:48 AM   #9 (permalink)
Proven Member
ilikespeeding's Avatar
Region: Southeast
Reputation: ilikespeeding is more helpful than not
Do not bypass your oil cooler. Do it right, or risk losing your motor. You choose.
1990 Eclipse GSX - Sold
1995 Eagle Talon TSi
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 10-04-2008, 11:56 AM   #10 (permalink)
Proven Member
LTUDSM's Avatar
Region: Tri State
could it be the bad oil sending unit???
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Im sorry but stupid exhuast question-- SikRacing97GST Newbie Forum 1 06-14-2004 08:19 AM
i think im stupid 91dsmeclipse Automatic Tranny 0 05-14-2004 01:40 PM
ported 1G manifold.....im stupid!!! Fattie92 Bolt-on Tech 4 04-05-2004 09:57 PM
im stupid ericismyname Newbie Forum 1 11-16-2002 07:58 PM
Page generated in 0.14215493 seconds (74.23% PHP - 25.77% MySQL) with 10 queries
