TurboTech7
- May 22, 2006
Confusion,
Maryland
Hello , i was wondering if someone could help me out with a slight problem with my hybrid build, some people call it homegrown. Anyway im having a slight problem making the factory tach work, and im here in search for an answer. First off the ECU and everything connected to is its a 1990 model non eprom and such, Does anyone know how to make this ecu more tach friendly? i mean without the use of a tacho interface or noise filter.im sure i could just pull the wiring out and mod it to a 92 + and get over that problem, but like i said im here in search for an answer so suggestions are welcome. The problem is i am trying to make a POSITIVE input tach work ) yes i tried feeding a ground pulse on the tach wire and it remained perfectly still,i feed a + pulse to it and it moves.So back to the question how could i make my stock tach work ? other ideas i had in mind is a switching circuit much like found in the RRE/ Magnus 6 bolt 2g conversions.Anyone else have a better idea ? if so please let me know, thanks in advance
