krkline2gdsm
- 59
- Mar 21, 2008
Hyannis,
Massachusetts
91 Galant VR4 #1320/2000. Bought the car BONE STOCK a few months ago. Did everything at once. What a mess this car was. Hoping for 300+whp and some 12sec passes. License plate: "ATEAV8"
Engine:
Stock 6bolt
BC 272 cams
Balance shaft belt removal (yes both balance shafts are still in the motor)
New timing belt
Unorthadox Crank/Water pump pulley
ARP head studs
ES urethane motor mounts
Rebuilt TB
90' oil filter housing
Emissions delete
Turbo/Exhaust/Fuel:
B16G ported
FMIC w/ 2.5" piping
Greddy RS BOV
2G manifold 7cm port
2.5" tubular O2 housing
2.5" downpipe (no cat)
2.5" exhaust w/ fart can
560cc Injectors
Walbro 255 fuel pump
Aeromotive FPR
ECU/Electronics:
Stage 3 Keydriver chip
SAFCII
GM MAFT 3"
Innovate LC1 Wideband w/ DB gauge
Misc gauges (boost, oil, water)
Drivetrain/Suspension:
Stock transmission/tcase (new seals)
BG fluid
ACT 2600 6puck sprung clutch
SS clutch line
Stock 3 bolt rear end
Solid bushings in shfter cables
1G shifter
ES urethane front control arm bushings
New ball joints
New tie rod end
Removed front sway bar
Other:
Modified driver side mount
Removed ALL PS components
Deleted 4WS
Manual steering rack
Deleted A/C system
Just actually got it together. Starts.. runs like crap. Having TPS issues. Have to diagnose the TPS. Either a bad TPS or adjustment/wiring issue. Then I have to tune it. Open to suggestions/opinions.
-K
Engine:
Stock 6bolt
BC 272 cams
New timing belt
ARP head studs
Rebuilt TB
Emissions delete
Turbo/Exhaust/Fuel:
B16G ported
FMIC w/ 2.5" piping
Greddy RS BOV
560cc Injectors
Aeromotive FPR
ECU/Electronics:
SAFCII
GM MAFT 3"
BG fluid
SS clutch line
1G shifter
New ball joints
New tie rod end
Other:
Deleted 4WS
Deleted A/C system
-K
