control arm rebuild
j-jamrod
83
Nov 8, 2007
Baltimore, Maryland
i is any way to rebuild or change the uper control arm ball joint in my 2G ???
You can either replace the entire control arm with ball joint already in it or you can replace just the ball joint. I don't believe that you can purchase just the ball joint from the dealer but I could be wrong.
Aftermarket ball joints are available but I have no personal experience with them and don't know how well they hold up compared to oem. You will have to remove the upper control arm, remove the defective ball joint and have the new one pressed in.
