avenger front end
j-jamrod
83
Nov 8, 2007
Baltimore, Maryland
i have agood deal in a complete front end from a 1998 dodge avenger, as i see the controll arms, tie rod look the same, any advise on it??? thank you
The Avenger has a longer wheelbase, otherwise the chassis' are identical.
2.0L Avenger radiator to 2.0L Eclipse RS radiator is the same. 2.5L Avenger radiator is different.
Most of the parts from the avengers will swap right over. Especially interior peices. The body's are different parts, but the front end will swap right over to a 2g if you have everything you need. I thought about doing a 2gb eclipse conversion on our 99 avenger..But is still on the backburner for now..
Avenger with 2gb front end looks good. A 2g with an avenger front end looks out of place.
If you do a front end swap, you have to swap the appropriate radiator support.
