My friend is a retard and thinks a twin turbo talon exists
He's probably confused with the 3000 GT VR-4 that had twin turbos.
In factory form, no, it wasn't ever made to my knowledge. As stated above, there have been people that made twin turbo talons, and there is also the stealth/3000GT platform that came with TT's stock. I believe they are DSMs, but normally called 3SI's do distinguish them from the much radder talon/eclipse/laser : D
Retarded setup, much better of running a larger turbo. Sometimes I don't get people.
Actually, there was one that a guy on here modded for a twin turbo setup. I think it was twin 16g's fueled by 2 external gates. Car was pretty bad ass before the shop that it was in burned up. Had a random name here on the boards too.
Stock, heck no. Those are all the 3000gt/stealth that run twin 9b's from the factory.
the Stealth/3000GT platform that came with TT's stock. I believe they are DSMs
They probably do qualify as DSM since they were part of the Chrysler/Mitsubishi joint venture. Most people reserve the DSM label for the Laser, Talon, Eclipse and Galant VR-4* , years 1990 through 1999.
1000 AAQ - Make & model info
*because of design similarities
I think I found the definitive answer. I stand corrected if this list is complete. There is no 13B turbo listed.
DSM: Top Ten FAQ
ok riddle me this...I have a td04HL turbo on my stock auto car...I have not seen this listed in the mhi turbo's
The 3/S platform is not considered a DSM, just like the Dodge Avenger isn't considered a DSM. It was made in the same DSM plant as an Eclipse, it carries DSM stickers on the chassis, and the interior of an Avenger is identical to a 2g Talon/Eclipse, but do we consider Avengers DSM cars? No.
91tizzy, you have a 13g.
I think you need to stop starting stupid, pointless, useless threads.
