boost help!
ok, then what else should i check to see why im losing boost and where should i go to get a service manual cause i guess the one i have was wrong about the compression
ok well i am pretty sure that it is supposed to be around the 150-160 mark so 100-110 is definately way too low. the best place to get a good service manual is directly to the dealer you might pay a little more for it but you can bet on it that everything in it is 100% correct.
1G (90-94) T/E/L 1.8L NT engine 2.0L NT engine 2.0L Turbo engine
Compression ratio 9.0:1 9.0:1 7.8:1
Standard compression 185 psi 192 psi 164 psi
Service limit 131 psi 145 psi 121 psi
so i was right its 121 for the 2.0 turbo
121 is what everyone on this site has told me when i said it was 150/// so which one is it
My haynes says 121psi is the service limit on a 1g turbo.
As for losing boost i would recommend a boost leak test. I big enough leak would cause you to lose boost
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
