headgasket
1990gsx1781
190
2
Jun 28, 2008
Lynn, Massachusetts
whats the thickness of a stock 4g63 HG im changing mine soon what do you guys think i should buy thats dependable
Well as far as headgaskets there are lot's of good headgaskets in the market, HKS, Power Enterprise, Cometic, Mitsubishi :dsm: 4-Layer Metal headgasket. I have used HKS, Cometic and Mitsubishi Metal head gaskets they have all worked well and are practicly the same i would go with Cometic is cheap and it has been proven to work just fine. :thumb:
The four layer Mitsubishi metal gasket (or any metal headgasket for that matter) should not be used unless both the block and cylinder head mating surfaces have been decked proporly at a machine shop. If you are just removing the cylinder head and replacing the gasket, send the head off to the machine shop and have them check the deck straightness. Just use a factory composite Mitsubishi headgasket with good non stretched OEM headbolts or ARP headstuds, and you will be fine.
