Fuel Pump Question
fatherbubble
273
Jun 20, 2007
baton rouge, Louisiana
Now heres a good question. Ok I know you can use a in tank an in-line fuel pumps at one time. Now the question is can you use an in-line one with a stick one in the tank, an if so what if it doesn't work will it stop the in-line one from getting fuel or not?
You can use an inline pump with the stock intank. Since the intank pump will be flowing at 0 pressure it will flow a ton of fuel. If you do it like that, i would wire them so the trigger switch on the inline runs off the intank, so if one goes out they both will. This will make your car stall rather than run lean and potentially ruin your motor. This is how i have it on my car, but I'm using a 255 intank too. :thumb:
