GSXdsm97
- 69
- Dec 25, 2007
galloway,
New Jersey
OK well first let me start by saying i have posted this problem before but now it is worse. I dont have my lap top becasue it got sent to service so i cant get any logs up. here is my problem,
my car will idle rought at 1500 go up to 2000 than drop to 1500 than go back to 2k.. it does this all the time. than if I am lucky it will idle right at 700. or it will go the down to like 200 and than stahl out.. I dont know what to check. I replaced my O2 so that is brand new I just put it in today any help would be great thanks
ps what should my AFP be set at
, you can do this while holding it, you will feel clicks. also if it is leaking around the seal wich mine was and resulted in the exact same symptoms. check the ISC first because it is the easiest with what you have to work with, but yes, invest in a small 5 gallon tank and build your leak tester, dont make the mistake of not regulating the air comming from your tank tho
