Ground Pulse Problem
bigolsackapoo
79
Jun 8, 2008
indianapolis, Indiana
Hi guys I'm considering buying a Talon, but it has a problem. It only runs on two cylinders. The owner says it is a ground pulse problem. He says that the ground pulse is not getting to the ignition coil to spark cylinders 1 and 4. Is this a hard fix? Also it comes with a laser for parts.
And while I'm at it is this a good buy?:
91 talon tsi awd- spark issue, Has:
super 16g turbo
fmic
3" hard ic pipes
after market bov
Cobra MAF
jdm block
91 laser rs turbo fwd- needs exhaust manifold and ic piping
all stock
Parts car
All of this for under 1k, good deal or not
Thanks,
Eric
Thanks guys. I would be paying from 600-800 for them, so I thought it would be a good deal.
Any other suggestions.
If its the ecu it'll cost 200 bucks for a new one. Would the one from the laser work or no because its fwd, and the talon is awd. The power transistor and the coil pack are no big deal.
