wishnfor4g63T
- 153
- Apr 29, 2006
victor,
West Virginia
Okay well I had a bolt stuck in the oil return line from the 16g. I was using left hand drill bits then bolt extractors to get the bolt out....of course i wasn't thinking and when drilling the whole i went thru the bolt then onto the turbo!!! I was like yay finally then i pulled the drill bit out and radiator fluid came leaking out...."oooo" i said that doesn't look like oil. Soooooooooo
BTW this is a slowboys Big 16G
Now i have a hole in my turbo right above the bolt hole. It's pin hole size not very big and i've already come to 2 conclusions as to fixing it.
#1 the easy fix put the bolt back in it. (thinking that theres a pocket that the fluid won't mix with the oil)
#2 pull the whole turbo off and taking it to a welder to weld the hole.
I hope that #1 will do the trick but in any form i gotta do what it takes to get this baby back on the road. I attached the image for u guys to see. TBH i don't want any guess answers i need the truth will #1 work or ill i have to do #2. Thanks for the help!
OH and to add to this i've heard that the 16g's don't really need water cooled. If this is the case i could just take away that part of it and be trouble free.
Note to picture. That pin that sticking out of the hole is the bit i used to extract the hole. It's not stuck in there it's just a refrence
