14b Turbo Help
DARKTSI
51
Oct 15, 2007
ELSINORE, California
i just picked up a 14b turbo for my 2g talon to replace the t25....its missing all the lines, the bolt that holds the turbo to the o2 housing i think and the wastegate actuator...can i use anything from my t25.....also can i get an external wastegate from ebay or sumthing....and do they sell any of the swap parts at autozone like the ss oil feed line??
Im pretty sure you can get the 2g install kit from turbochargers.com to fit the 16g and 14b.
keep the O2 housing bolts. you will reuse them. pick up an extra manifolt to turbo bolt. that way you dont have to re-use that damn stud. im not sure about the oil lines, but i would suggest getting new stuff. the 2g install kit is definately a great idea
+2 on the Install kit, and +1 on the bolt, that stud is a pita. You can reuse your water lines, but deff get the kit.
Those install kits are overpriced and you really don't need one.
Who wants to spend money if you don't have too?
You can re-use your water supply lines with minor bends. you can re-use your oil return line with slight slotting of the bolt holes.
You can use the stock 14B discharge elbow. the stock lower hose can be used with it.
You DO NEED a NEW SS oil supply line.
You SHOULD get a bolt to replace that stud.
Good luck and only by thee things that WILL make a difference!
Like he said^, 2G kits are a waste of money. reuse your water lines, just force them where you want them to go. I would get a oil feed relocation kit just because the feed from the head blows. Ditch the stud on the O2 manifold if you can get it out, dont waste all day or phuck it up in the process. Pretty sure your wastegate from the T25 will NOT work, and dont get a external wastegate, youd have to weld the flapper door shut and its really pointless unless you had like a 20G. Just pick a one from another 14b or 16g for like $20 USED.
