What is this??
ozzie_1978
88
May 5, 2008
Augusta, Georgia
It's not comin up on google
<a href="http://s17.photobucket.com/albums/b52/ozzie_1978/pics%20i%20took/?action=view&current=100_1594.jpg" target="_blank"><img src="http://i17.photobucket.com/albums/b52/ozzie_1978/pics%20i%20took/100_1594.jpg" border="0" alt="Photobucket"></a>
its a turbo...what do you need to know?
You have a keen grasp of the obvious :toobad:
I believe he is more interested in what KIND of turbo it is.
More pictures would help, along with maybe some measurements of the housing/impeller
Okay, you want to know what model/trim etc... that would've helped in the original post... Like I stated first, more pictures would help, as well as the measurements of the housing, impeller, etc. as zero97tsi said.
Shood me some minor diameters (and major diameters if you're not lazy enough to pull the housings). I'll tell you in a quick minute what wheels they are and their potential.
That is an E compressor cover.
Is the turbine housing a t3 style turbine inlet? If so there should be a 48 63 or 82 in the inlet. There you will find your turbine a/r.
You kind of lost me, im not lazy so if you explain it to me I'll do it
Is it the pic or are the blades nicked up .
its not the pic, the blades are all nicked up. theres also up and down shaft play. enough that when u push it one way or another it scrapes the housing
so the part number doesnt help me figuring out what it is?
