Quote:
Originally Posted by 64_Frankenstein
Seems like your turbo have a oil leak. Too much oil is bad and lightly wet oil is ok. This normaly happen to a ageing turbo. How old is your turbo? If the oil look fresh after you accelerate the car then the oil ring seal in the turbo is shot. If that happens it need to be rebuild soon or get you new turbo. If you have a good driving habbit you don't have to get it rebuild or buy you another unless the turbo is leaking oil very bad. In this case I'll buy me another one just in case the one I have now failed completely.
The oil your seeing in the turbo could be from bad seals, but chances are better that it is coming from your breather valve from the valve cover. If it not a bad turbo, simply installing a catch can like this
HUSKY 1/4 In. Air Compressor Filter - HDA70400AV at The Home Depot
... or just making your own.
