mezer
- Apr 26, 2008
Lafayette,
Indiana
Hi, so I've wanted to buy a 92-94 talon for a long time, and finally received the opportunity from a friend. He offered me a good deal, and I became the owner of a 92' Eagle Talon TSi AWD, unfortunately it's an Automatic, and unfortunately that's my current problem
The basic problem:
The car goes into neutral, drive, reverse, etc fine, but does not shift up from 1st, it doesn't even attempt to. Note-- It is not in 3rd gear, it IS 1st gear. The transmission light is on on the dash, but I haven't had the time to check the codes, and figured I'd ask here real quick if anyone knew whether this was a bad transmission or something electrical internally since I have a spare transmission I can steal stuff from.
Some background:
Bought the car from a friend, who purchased it from another guy, he said it had a bad timing belt tensioner and that the guy he got it from said the transmission was also bad. I replaced the timing first, and noticed while doing this that the flexplate was only held on by 1 bolt and was pretty much destroyed. When I purchased the car he also gave me a 92 awd tsi transmission from a junkyard, so I was torn as to whether the transmission was actually bad or if it was just the flexplate.
I was pulling the transmission out to replace the flexplate and realized the bellhousing was cracked, so I figured screw it and decided to throw the junkyard transmission in. That leaves me with my current problem. Also please note that when the original transmission was in, that the transmission light did not come on on the dash. I started it to see if the timing was right and to assure valves weren't bent, so I know this for sure.
So uh, anyone have any clue?
The basic problem:
Some background:
. I found someone parting out a 92 though, so hopefully he'll sell me his and it'll be good. Thanks for the offer though.
