evo9mrtt
- 43
- Apr 15, 2008
Arvada,
Colorado
I dont know why but my cars 16g actuator is making my car push 17psi+ at times. It holds true to 10/11psi until about 4800rpms then starts to creep up to 17/18 psi. I have no boost controller and i took the vacume lines off the stock bcs and just tied them together with a T. My friends have done this and their 16g's only would push 7psi after doing so. What could be causing this? I'v heard that when you do upgrades to the exhaust and intercooler and intake setup that this will raise you boost, but raise it to 17psi? It seems high. I do have the whole fuel system upgraded and have DSM link but still. Also my coolant keeps overfilling my catch tank and then flows out quite often. I just got home from work and looked to see if it still was doing so and it was almost a constant flow coming threw the overflow hose. It would stop at times and then start again. Then after the car turns off it lets out a good splash and my upper radiator hose feels like its full of air. I was told to replace the radiator cap and see what that did and to have my car compression tested to see if i have a blown head gasket. So i did and my cars compression was 135 acrossed the board and the cap didn't do anything. I also checked for coolant leaks and didnt find any. I'v done everything i can think of. Any ideas to what it could be?
. As far as my turbo goes i know for a fact its not ported. Its a small 16'g that is quite old now so im going to replace it with a new turbo. I was thinkng about going with a PTE 50, 56, or 57 trim with a DNP manifold with a external gate setup. Either that or going with a FP3052, or 3065. I dunno yet though
