Turbo seals.. pictures of inside turbo
spyder97gs
777
6
Dec 10, 2004
Greencastle, Indiana
I've posted about a smoking problem and when I checked for shaft play I had a ton in ALL directions but the fins are still fine. I've been smoking and losing ALOT of oil. About a quart per 100 miles. I pulled the turbo and I don't really see much WET oil.
Anything look wrong with any of those?
I just went and pulled the IC pipe that connects to the throttle body and there was a ton of oil in there. From both sides. There was a stream into the TB.
Pull the LICP off the intercooler with an oil drain pan underneath. That's the lowest point in the intake tract.
Did that, and nothing came out :beatentodeath:
I'm picking up a new turbo tomorrow and throwing it on so I should know within 24 hours if thats my issue or not. I pray it is!
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
