SPark plug wires help.
Kalisko
267
Mar 19, 2008
Lawrenceburg, Indiana
Hey guys I just got new spark plug wires for my 92' GSX and I installed them to the manual's specs and my car is very sluggish now, the RPM's will barely even go up. I installed them in this order. Anyone have any suggestions?
valve cover
4
3
2
Coil pack
1234
Make sure you have the wires pressed all the way down onto the plugs. Likewise with the pack. Maybe you just have a bad connection. You can check the ohms of each. I don't know how or the numbers you should get. Someone else can fill those in.
I'll do that. I'll pop them out in the morning and make sure each is connected good. Then should I let her run a few before attempting to move it? Also on a side note I installed a B.I.S.S. Screw today too beings it was missing one. it idles fine but with the screw tightened all the way down could that cause it to not go as much too? (doubt but just trying to help illustrate everything)
Sounds as simple as having them plugged in the wrong place. Mine did that when I put them in the wrong fire order, sounded like a go-cart. Luckily I had pics of the engine and could eyeball where the wires were swapped.
