Head Gasket
Daaan
229
Aug 15, 2007
Courtice,
hey everybody,
Im replacing the head on my 1992 eagle talon and im not sure what the bolt pattern, and bolt torque to place the head back on with the gasket(new gasket). If anyone has the bolt patt/torq specs please send them this way
And any tips when rebuilding the engine would be great.
thanks everyone :talon::thumb:
You mean no oil in the holes that i tighten to 72 pounds right?
And should i pre-tighten all bolts to say, 50 pounds.. then tighten the first one to 72, and so on?
or is this bad
I like to come up to torque in 3 stages, 40%,60%100%. Do each step a couple time as you'll find the center bolts are lose after you finish a pass. 3 passes at 40%,,,3 passes at 60%,,,,, ect.
cruisintalonawd said:
Why in the hell would ARP tell you use their moly lube or 30w???? You can have oil in the bolt holes
If you hold the stud sideways and put a couple drops on the threads (just enough to cover the threads not letting any on the bottom of the stud) and then screw it in, the oil will come out of the top of the hole as the stud is screwed in.
or is this bad
Yes those are the holes I am talking about.
I always tighten in at least 3 steps. Doing more steps won't hurt anything. If I was putting in stock head bolts I would do 25,50,75. 3 extra ft/lbs isn't going to hurt anything either.
