Looking for new O2 Housing
99GsxMD
89
Dec 16, 2007
Calvert County, Maryland
Is it worth buying a new o2 housing or just getting the stock one ported out? I have the RRE downpipe to bolt up to it. I want to get a new one but just trying to get some ideas. Which is a good one to get though, need some info! Thanks
If your still running the stock t25(assuming from your profile)there really is no need to upgrade or port your o2 housing,if you really want to upgrade,porting would be my suggestion,as it is the cheapest alternative.I would hold off on buying another o2 housing until you've decided exactly what turbo you will be upgrading to.
Well i will be upgrading turbo soon, thats the main reason i am getting it LOL. 50trim
I would just port the stock one. The only way I would buy one is if you need it for a new turbo, for example a v band outlet turbine housing. If you are going with a bolton housing you won't need a different one though.
Defenitely just port the shit out of your o2 housing. Cheap and very effective.
Don't buy a o2 housing till you got the turbo you want because you can end up with a different setup and you will just end up buying twice and losing some money
easiest way to do porting on my own?
