6boltscooter
- Mar 26, 2008
B-town,
Idaho
I have been told my various people that running 750cc injectors with a MAF-T will give too advance of timing. Seeing that the ECU is thinking only 60% (i.e. 450/750) of the air is really getting to the engine, the ignition timing will be more advanced than it really should be. Driving around at 15 psi, the car pulls ridiculously hard (relatively). I can even feel it advancing towards the top end. There is no oddness or wierd dips in the power, just lots of it. I would like to keep this setup just the way it is but I want to be certain that my headgasket is not going to bust or chip a ring land. I run 93 octane gas with a nice big FMIC so I would think I have some safety room for more boost. I'm pretty good at determining when a engine is knocking and pulling timing. If I can't feel or tell that the knock sensor is pulling timing, is there any real reason why I can't run like this? The knock sensor should have the final say shouldn't it? Can I blow an engine with simply too advanced timing if there is no knock?
Thanks!
Thanks!
