TSi90
- Dec 6, 2002
I was just wondering if anyone has got there valve stem seals replaced latley and i was wondering if you have to pull the head off the car to replace them.
Originally posted by TSi90
I was wondering if you have to pull the head off the car to replace them.
Originally posted by fivestardsm
Well, usually you do, but you can presurize the cylinders and pull your valve springs in order to replace them. It's not tooooo hard, you just want to make sure that when you do each cylinder, that you have the piston in the cylinder that your working on up as far as you can so that your valve(s) don't fall out if a problem comes up and you loose your air pressure.
Steve.![]()
Originally posted by TSi92
Just do it the right way. Worn valve stem seals usually means worn valve guides too. Just pull the head out and have it overhauled. Besides, I did the VFAQ valve spring compressor mod and it won't fit with the head on.
Originally posted by GTM
I've done this job on various cars at least 10 times and I average about 1 comeback a year. I spent 5 years as tech inspector with SCCA, have a provisional teaching credential and an associate member of SAE.GTM
Originally posted by JJay
GTM thanks for your 2 cents worth. ...
After I got back from my trip and the car would sit for any amount of days or even 1 day it initially blows out some blueish/white smoke for a minute then warms up and it goes away.
The Valve stem seals are (I think) giving out after 152,000 miles and I suspect that they leak when the car is shut off just sitting. How much money should I expect to pay to get this fixed. Thanks a lot.![]()
a few independants and my own Lancia specialty shop.
