ecu bothering me
scaryfastdsm
70
Jan 9, 2008
bonney lake, Washington
ok well i took out my ecu in my 91 gsx so i could hook up my air/fuel gauge and it put it back ever since then my electric door locks do not work and my radio wont turn on. i have constant power to it and a ground but it will not even turn on. my amp turns on, even still on key....any suggestions would be nice on how to fix or what to look for.
Maybe you pulled the connector from the stereo when you were working with the ECU. If you disconnected that or shorted it they are most likely on the same fuse and that's why the doors don't work either. Does your dome light work?
