Clutch question.
keithscianna
Banned Member
78
Oct 20, 2006
denver, Colorado
Ok well my clutch is slipping at 14psi, I turned it down to about 6 and now its fine. If i keep it at about 5 psi, how long can i keep milking this clutch. B/C i am broke right now and this is my DD. Also the previous owner stated that there are only 1500 miles on it.
thanks,
I looked at the clutch pedal, It seems that it is adjusted as far as it can go back. If i adjust it toward the master cylinder will it make the clutch release all the way?
It's been almost 2 years since I had to work on the clutch and I can't remember off the top of my head which way it goes to "tighten" the clutch.
Maybe someone else can chime in. If not I can look through the CD when I get home tonight.
I have a slipping clutch also, have my boost turned all the down to 9-10 psi. But Clutch slippage could be from many things. Oil could get between it and cause this, improper springs on the pressure plate causing less clamping pressure. Also, like previously stated, improper break-in. I would play with that adjustment if easy to do, and find out if that makes a difference. I like to just stay out of boost till i can also afford to replace my clutch, this also saves me gas. I like to think on the bright side, but I also miss my neck snapping pulls. :D :dsm:
Well i did adjust the pedal and it worked!!! I put the boost back up to 16 and ran it like crazy and the clutch held up perfectly. Thanks for the help guys.
keith
