CompuBob_TSi
- 72
- 1
- Oct 17, 2007
Windsor,
I did some searching and I did not come up with a solution to reattach the rear defroster wire to the window.. a few people suggested soldering it back on, but others said this will not work, I don't think you will be able to heat the part on the window enough to get a good solder and it will just break right off again..
is there any type of conductive epoxy that will work? or maybe a dab of conductive paste in the center of the connector and epoxy around the edges?
if soldering is the only option, I assume you could heat both parts up with a torch, but I am afraid of cracking the window.
