karacing
- Sep 21, 2007
Central Florida,
Florida
Alright first off my first gear was starting to go, it kept grinding worse and worse every day till the point i cant even put it in anymore...yes i did a few launches probably the cause. So i replace the Master and Slave cylinder for the clutch and bled it and everything then now its hard to shift into 3rd and 5th sometimes pop out fifth, and when the car is hot or after putting it in WOT for mybe like a min it wont go into any gear. At one point the car smelled like clutch for like 1/2 hr but i didnt launch it or anything. I need a cost-effective solution not "rebuild the whole thing" if your going to say that please dont bother posting thank you BTW my car is 1995 Eclipse GSX 5-speed
enjoy
