Needsoles
- 154
- Aug 9, 2007
windsor,
California
so i have a set of 550 injectors on my 1g eclipse so my question is can i run a 190 fuel pump or do i have to run a 255 fuel pump
the amount of boost you are running has everything do with the amount of fuel you use.
the amount of boost you are running has everything do with the amount of fuel you use. So you could theoretically run out of fuel even on that setup at really high boost pressures.
No it dosen't! 20psi on a 16G is going to use alot less fuel (and make alot less power) then 20psi on a t3/t04e 57trim .63ar. The amount of POWER you make has everything to do with the amount of fuel you use, get it straight.
The injector will run out before the pump at factory base fuel pressure, and the fuel pump was in question when compared to the injector size, your comment is irrelevant.
The rising rate is only to compensate for intake manifold pressure. Relative pressure at the injectors remains the same. 550 is 550 regardless of which turbo and how much boost.matthewdesigns said:I am aware that a larger turbo will move a greater volume of air at a given psi than a smaller one, and will therefore require a larger amount of fuel to be mixed with the incoming charge. My point was that as our cars operate on a rising rate fpr, the boost pressure has a direct relationship to the amount of fuel your car will be required to provide, above the base level. I have it straight, thanks.
the 190 is good to 400hp, and up to 30 psi. YOu will be fine, rewire the fuel pump for the extra little bit.
I know what you are trying to say. . . but to clear any misconception. . . The 190 is definately not up to the task at 30 psi for my setup. Boost, at best, defines flow arbitrary to the setup.
30 psi is 350whp territory to a stock 4g63 longblock an an evo3 16g.
30 psi is 500whp territory to a stock 4g63 shortblock and cam upgrade and t3 stage3 50-trim.
30 psi is +650whp territory to a stroked 4g63 and cam upgrade and PTE 6176.
The 190 is good to 400whp. But not at 30 psi. It's 190 lph flow number is at 43.5 plus atmospheric pressure. It lessens greatly as more pressure from the pump is required to maintain injector flow consistancy, which Wret discusses above.
Oh, there's a lot more. You need to start by setting the mood.is there anything else that anyone would have to do, besides putting it in?
Well some have problem overrunning the stock FPR. Some have not. That is probably why you get the mixed review. . . Now I know Walbro makes a 190LPH High Pressure pump. Perhaps this is the particular 190 that can overrun the FPR. The regular 190 is fine for an evo3 16g or smaller in potential.
