dan2288
- 577
- 1
- Sep 9, 2006
Shillington,
Pennsylvania
Ok, so where the cam angle sensor should be, I have a plug there that poped out while I was driving ? Now my whole engine bay is covered with oil. What would cause it to pop out ?
If so, on a '95, there is no exterior cam angle sensor, so they put a round rubber plug, similar to the half-moon gasket. For some reason, you don't get a replacement ROUND plug with a new valve cover gasket, but you do get a half-moon gasket. Don't ask me why. You MAY need to go to Mitsubishi to get the round piece. I wouldn't run the car until you get it replaced. While you're in there, you might as well replace the whole valve cover gasket anyway. Don't forget a little RTV.
