spawn7037
- 234
- Nov 3, 2007
San Antonio,
Texas
I went to start my GSX this morning. It turns over and starts but as soon as I get iginition I hear this real loud clanking sound. Its rythmic and doesn't sound like a rod bearing, the sound is higher up in the engine.. I was wondering if maybe this could be associated with the ignition coil. Its the only thing I can think of since the engine misses a bunch more than it usually does. I was thinking that maybe its the powersteering pump, but the power steering still seems to work. (I used to work at a hydraulic pump shop) I know, change plugs and wire, but it wasn't doing this until now. I had just drove it home last night and it was fine. Any ideas? BTW I have a engine out of a galant vr-4 swapped in my car
It was a loud rythmic clanking. In rythm with the ignition. VERY Loud. My friend had to plug his ear as he got closer to the motor.
I went back to the house and took the head cover off. All the lifters are fine. There aren't any shavings in the oil either. I tried starting it again and it sounds like gears grinding in a constant rythmic patern, like I said it matches the ignition pattern. Could the starter be half engaged or something down those lines?
I don't think its a valve. They look fine, but sometimes thing aren't how they seem. My next step is to pull belt cover and see if I can see any thing wrong with the belts and the balance shaft.
Okay, I will try that, it might be a week though, I don't have a good internet connection.
