waa95gsx
- Oct 5, 2007
Charlottsville,
Virginia
I am having this problem with my 95 GSX. I did some research and found some info on it, but I still am stuck in a rut..
My car is pretty much all stock, no mods as of yet I am just trying to get her to run right first. When I drive normal the car is fine, its when I go to pass someone or ever get on the gas a little bit the car seems to buck or hit a fuel cutout of some sort? My plugs, wires and coils are all new so it's not that. To get to the point, im stuck between the fuel filter and the cat convrt 02 sensor? I was reading up on the problem and someone mentioned disconnecting the sensor around the cat and it should fix the problem. I was thinking it was the fuel filter, but sometimes when you floor it it bogs out and makes a popping sound or something in the exhuast?? it's kind of hard to explain..
any tips or ideas would be greatful. maybe even links if i missed something when searching. thanks guys!!
As last resort bought some high price spread plug wires and new plugs and the problem went away. Ended up being one of the inslator boots started to burn through and only showed up under boost.
