16g se up help
erald01
661
Jul 6, 2007
canton, Michigan
i just got done installing the evo3n 16g with evo manifold and o2 sensor, also installed 650cc injectors fuel pump and the keydiver chip...i tried starting the car but it would not start:cry:...it cranks but that all it doesd can someone help ma and point out things that i must have left out or what could be the problem..thanx
Are you getting spark?
Are you getting fuel?
Did you reconnect all the intake piping?
Is the MAS connected?
Start there then report back
im getting all of it..im getting fuel cause i can see that my fpr gauge goes up and my sparkplugs are getting wet and im getting spark, i did reconnetc all the piping and the MAS, i even swapped the plugs around since i have a keydiver...i dont know what to do anymore.
If you are sure you have spark are the plug wires on the correct plugs?
With the plugs all wet with fuel they will not fire, you need to leave the plugs out of the head, unplug the injectors and turn the car over a few times to clear out the fuel. then reconnect everything and try it again.
