caspers_dsm
- Sep 24, 2007
Hampton roads,
Virginia
It recent aquisition of my new DSM, i received a seven bolt shortblock.
In my recent hours of searching on my new toy and the infamous "crankwalk", i have found the block and crank aren't the problem, its the assembly (clearances in the bearings). That being said, there should be no reason why using a seven bolt for a rebuild, if done with tight clearances, would be bad. I am not knew to engine assembly and i know any "sloppy" crank assembly is trouble.
I would also like to confirm..... a rebuilt shortblock using 1st gen "big rods" and forged pistons with removed B.S., will handle mid 300 maybe even 400whp.
Thanks guys. I hope to get this thing underway.
Daily driven w/ a 50trim and ~20psi
