PimpDrive
- Nov 11, 2003
milwaukee,
Wisconsin
Hi all, first off I would like to say this is a long one and I have done a boost leak test about 2 times a day for like 3 weeks now since I replaced the engine(every time i replace something I do a boost leak test). Last year I had a problem with my car sputtering under boost, any amount of boost, even 1 psi, and it would continue to sputter until I turned it off for a few mins. So basically I had to drive my car nice and slow so it would never go into boost.
So after months of confusion and fixing stuff, I still had the problem, I checked compression and 3 cylinders were strong but one was 130. pulled the head off and it looked as if a small set screw or something went into the motor, beat up one piston, then popped out, went into another cylinder and did the same thing, and then it destroyed my new evo316g turbo. So I thought I found my problem, a bad engine, maybe preignition or something from hot spots on the head or pistons throwing everything out of whack.
So I finally got a new motor together, block, pistons, head, gaskets, almost the whole nine yards. started it up, made sure everything was good, took it for a spin and the same thing happened, small amount of boost and it would start to sputter and putter as if was running on 2 cylinders. got it home, did a boost leak check, biss was leaking, tb shaft seal was leaking. so i replaced and fixed and it still does it.
What I have done so far was, replaced the coil, plugs, plug wires, isc, tb, tps, map sensor on top of intake mani, injectors,o2 sensor, fuel pressure regulator, fuel filter, all the gaskets,coolant, oil, tranny and trans case fluid, alternator, cam position sensor(on the intake cam sprocket)all that on top of the new long block i built.
I have a 14b with a tubular exhaust manifold on it, tubular o2 housing, 3in exhaust with no cat, boost gauge, fuel pressure gauge on the filter, I have done the "TABOO" vacuum line delete, except I did not delete the stock "boost controller". this method I found here
http://www.dsmtuners.com/forums/showthread.php?t=198327&highlight=taboo
I also took out the AC stuff when I put the new motor in, The ac never worked anyway, So the harness that connects to the ac compressor is just zipped tied securely in the engine bay.
The things I have not replaced was the coolant temp sensor, mas air flow sensor, air filter, ecu( I took it out and inspected it, it looked as if no caps popped and everything looked good), fuel pump, the wiring harness for the motor, knock sensor, thats all I can think of really.
Like I have said, Do boost leak tests on a daily basis to 25 psi, the only thing that leaks is the pcv and it bleeds of very very very slowly. I have routed the vacuum like directly to the stock fpr( which seems to help a little), So anyways, now I can get it to about 5-7ish psi, it sometimes does not sputter, but 95% of the time it does. its very annoying.
I HAVE A AUTOXRAY EZ-SCAN 5000! (does not read knock.. ghey)
So, let me tell you what this thing has told me, even though it does not give me as much data as I would like. After starting the car and letting it sit till it gets to operating temp it reads
Fuel system 1 = closed loop
load value = 20%
coolant temp = 185 deg F
short term fuel trim = 0.5%
long term fuel trim = 0.5%
engine rpm = 780 rpm
vehicle speed = 0 mph
ignition timing adv = 7.0 deg
intake air temp = 69 deg
air flow rate 0.4 lb/min
throttle position = 0%
oxegen sensor = 0.100-0.800 V(it bounces back and forth)
So after driving the car, I get it into boost(5ish psi), it starts sputtering, but instead of turning the car off to make it stop sputtering/missing(sounds like the car is not firing 2 cylinders) I blip the throttle a good 5 times over about a min and the sputtering goes away. But then I have high idle around 2-2.5k and the scanner reads
load value = 20%
coolant temp = 205 deg F
short term fuel trim = 7-8%
long term fuel trim = 7-8%
engine rpm = 2000-2500 rpm
ignition timing adv = 25ish deg(give or take a few)
intake air temp = 90 deg
throttle position = 4%
Also, when I do a boost leak check, I get no leaky noise other than the pcv a little, but I get a very faint "dripping noise" somewhere in the engine( i have a small oil leak somewhere if that could have anything to do with it), Im going to find the leak once I am no longer preoccupied with getting it running right first. But is this "dripping noise" normal when doing a boost leak check? and should it be used for diagnosing my problem?
So If anyone could pinpoint the problem it would save me from blowing money on(try this, that was my problem)parts, this problem has cost me too much and i was already broke before hand. please ask whatever questions you may have, it has had me stumped for over a year.. I will have one of my lady friends bake and send you a bunch of cookies, or Maybe I can send some proven to be not defective 2g parts.. haha, if anyone can figure this out, I would appreciative and think of something.
I can take vids or pics if anyone would like, and if it comes down to it, where can a cheap logger? I do not know anything about where to get a logger, all I know is that I need one.
THANKS!
Jerm
load value = 20%
load value = 20%
THANKS!
Jerm
