bodydropped92
- Aug 23, 2007
Crawfordsville,
Indiana
Do I need to change the engine wiring harness and computer to do a automatic to manual swap on a 95 Talon TSI AWD? Any and all info would be greatly appreciated. Thanks.
All i know is you do have to change the ecu out. the auto ecu's are set for different size injectors and also pull more timing. if you are using dsmlink or something of the sort then you dont have to worry about it because you can just change it.
