Benbon
- Feb 11, 2007
East Haddam,
Connecticut
I just purchased a 95 tsi awd with a 6bolt swap/injen intake/random 3" exhaust. On the way home a warning light came on which I found to be the low coolant light. As I was parking the car I noticed white smoking coming from underneath the hood. After closer inspection I noticed white smoke coming from the turbo. I let her cool down and put in anti freeze solving the warning light issue and I checked the oil level which is fine. I started the car and let it idle for a solid 10 minutes and did not have anymore smoke coming from the general location I mentioned above so I took her for a ride. Everything went smooth on the quick ride around so I brought her back home and parked it. I noticed smoke coming from the turbo again!! I have searched and all I can find is members talking about a blown head gasket but if that was the case it would be smoking from the valve cover area (I'm assuming). I'm going to take the intake pipe off and check for shaft play in a few hours. Any suggestions? If the 14b has no shaft play, what should I check next?
The car does not smoke when idling no matter how long I let it sit but right after a 5 minute test drive, it smokes from the turbine which makes me think the 14b is shot. Assuming my thermostat is working properly, the car does not overheat from what the gauge reads and if it doesn't smoke whiling idling, It can't be the head gasket..right? I'm just so worried of blowing my motor. I want to get this situated so I can move on to basic maintenance before I go through with my winter upgrades.
