gridlyne
- 213
- 7
- Aug 15, 2005
Queens - Woodsi,
New York
Hey guys, Im rebuilding my motor with stock internals (2g Pistons on 1g Rods) and HKS cams in the head. 550 injectors and nothing else pretty much. I will probably run no more than 18-20lbs (Max) of boost.
Im looking for a good rebuild kit. Right now I am stuck between two head gasket choices. Which is better suited?
The Cometic or the OEM 4 layer metal head gasket? The other question is what thickness would I need with the Cometic. I saw varrying thickness's?
Example:
http://www.dsmparts.com/customer/product.php?productid=396&cat=122&page=1
I plan on auto crossing the car and will put most of the money into wheels, brakes and suspension. So besides a larger IC, turbo and Feul pump I wont be adding anymore power to the motor.
Thanks in advance. And I apologize in advance for the vague noobish question.
Example:
