tom04841
- 611
- 6
- Jul 21, 2004
Rockland,
Maine
Block was rebuilt about 2000 miles ago. It has been smoking since the rebuild/BSEK.
The shaft seals on the turbo are not leaking.....I have removed the turbo to verify that.
Reman'd head with viton seals.
I honed the cylinders and made sure all the end gaps of the rings were withing specs.
Replaced pcv valve with 2 different OEM valves....no change.
Compression is at 125 across all 4 on a cold motor, oil to each cyl didn't increase it...keep in mind I have a set of webcam cams.
Rolled # 1 to TDC, put compressed air to the cyl, blocked pcv and vc breather, and had a very tiny bit of a hiss from the oil fill hole....nothing you could feel, but could hear it. Nothing from the intake or exhaust either
Car runs GREAT!! The smoking is irritating me though. I can't figure out the source and it is driving me nuts.
