grams per rev???
notsofastdsm55
61
Jun 20, 2007
kailua, Hawaii
Does anyone know how to convert grams per rev to lbs/min??? and is it possible to convert g/rev to kpa???(ok I really doubt that as g/rev is airflow and kpa is pressure but I thought I'd ask)
1 pound = 453.59237 grams.
1 gram = 0.00220462262 pounds.
Ok I took the flow conversion site and did this, I took a g/rev value and say 2.1 and the times it by an rpm number say 7000 which gave me grams per min which =14700 then used to converter to get 32.407lbs/min, Is this accurate or is my method wrong??? its has been awhile since school!!!
Assuming revs, you mean Rotations per minute.
Take your grams/rev * X (Rev/min). That cancels your revs, so you have grams per minute.
Then grams/min * (1 lb/ 453.59 grams), then you have lbs/min.
So in short take grams/rev * RPM / 453.59= lbs/min.
