cooldude919
- 185
- 6
- Feb 19, 2007
Cape Girardeau,
Missouri
Installed wideband about 2 weeks ago and installed Hahn sidemount with upper hard pipes today. I just have the stock o2 housing and seem to be getting some pretty good creep. In the upper rpms it will spike to 20-21psi(should have ported stock o2 or gone aftermarket when i put in 14b, oh well). During this whole time the wideband never goes leaner than around ~10.8, mostly seems to be around 10.5. From what ive read this is on the rich side of things correct? The only thing i am missing is a logger, which i am going to either get soon, or just go for DSMLink since i have a 95, trying to decide what route to go.
I also seem to be running around 12.8-low 13s at idle and normal cruise, which from what i read also seems to be really rich. Im still on stock injectors(as far as i know, bought the car off ebay a while back, they didnt say anything about fuel mods, but who knows) so its either they arent stock, or the fuel pump isnt stock and the rewire is making it overflow the stock AFPR. Basically my worry and question for now is if im running that rich, should i be safe knock wise? With this thing spiking to 20psi, if im still around 10.5afr then i should be ok? I know everyones going to say get a logger
and im working on it.
Thanks for any help or tips
and im working on it.Thanks for any help or tips
