95EclipseGST
- 406
- 1
- Mar 1, 2002
Kansas City,
Missouri
I just raised my car up 1/2 inch today and thought maybe i did it wrong. I raised it up by the collars at the bottom of the spring. BUT, when i was finishing up, i noticed at the base of the coilover, it unscrews from there also. So you could raise it and lower it from there also? Did i do it the right way? I want my spring rate to be about the same as it was, but the way i rasied it, compresses up on the spring, seemingly making my spring rate stiffer. The directions that came with the Tein Flex, basically give you the specs of how to set them initially or for optimum performance. Anyone tell me if im doing this right? Thanks
How does the -1.2 degrees of camber sound though? Actually my left side camber is -1.2 and the right side is -1.6. The coilovers are exactly at the same heights though and the guy at goodyear said thats not far off at all and not to worry. What do you guys think. Should i mess with the right side just a bit to try and achieve -1.2 on that side as well, or is the goodyear guy right, that its no big deal. Just knowing that its slightly off kinda bugs me though. Is this truly nothing to worry about?
